fault abs
Its the actual break pedel it only happens once or twice a day,very slight iv changed the break pads and disk's also new front swivel joints bareings and gascits check the sensors at the front and they seemed to be pushed in all the way.
bled brakes seems to have cured it ,need advice what size bolt hole in the rear axle were the prop shaft joins the dif i need to change the oil seal need to make some kind of tool i was thinking of a bit of all thread with a washer on the end and some kind of slide hammer to knock it out
did you download the RAVE manual for your truck? go to www.landroverresource.com it will tell you everything you need to know and more.
kbarker27
Oct 13, 2023 04:03 PM
06Range
May 8, 2013 09:01 PM
