fault abs
Old Jun 17, 2010 | 01:23 PM
lawson's Avatar
Default fault abs
have landrover discovery 300 tdi 97 model abs keeps kicking in for no reason new discs and pads on front any suggestions thanks
Old Jun 17, 2010 | 02:31 PM
hilltoppersx's Avatar
the abs light is coming on? or the actual brake system is engaging??
Old Jun 18, 2010 | 04:34 PM
lawson's Avatar
Its the actual break pedel it only happens once or twice a day,very slight iv changed the break pads and disk's also new front swivel joints bareings and gascits check the sensors at the front and they seemed to be pushed in all the way.
Old Jun 18, 2010 | 07:27 PM
you bleed the brakes properly?
Old Jun 20, 2010 | 02:18 PM
lawson's Avatar
i will bleed them again and hope that does the trick thanks
Old Jun 23, 2010 | 01:54 PM
lawson's Avatar
Default abs
bled brakes seems to have cured it ,need advice what size bolt hole in the rear axle were the prop shaft joins the dif i need to change the oil seal need to make some kind of tool i was thinking of a bit of all thread with a washer on the end and some kind of slide hammer to knock it out
Old Jun 23, 2010 | 07:12 PM
what? your trying to change the rear dif oil? thats post is a tad bit confusing.
Old Jun 24, 2010 | 10:28 AM
lawson's Avatar
the rear oil ceal
Old Jun 24, 2010 | 11:00 AM
did you download the RAVE manual for your truck? go to www.landroverresource.com it will tell you everything you need to know and more.
06Range
May 8, 2013 09:01 PM
jmason
Mar 12, 2013 08:08 PM
anhernandez
Aug 18, 2009 12:47 AM
cottonpatchweims
Jan 14, 2005 01:59 AM
