Power Seats
Old Aug 12, 2011 | 02:41 PM
esievel's Avatar
3rd Gear
Default Power Seats
Hello All,
I have an 89 Range rover classic. I really don't like the power seats and power windows. I live in New Mexico. The hot dry dusty climate causes switches and motors to go bad. I've been thinking about changing my seats to the old fashioned manual style. Does anyone have and experience or thoughts about this? Currently my driver seat is stuck too far forward. I can still drive but it is a bit uncomfortable and unsafe.
Thanks for any input
Old Aug 12, 2011 | 03:16 PM
Some members have reported taking the drive cable out of the seat motor, and using an electric drill to move the seat to a desired spot. Guess that might be OK. I have also scavenged parts from ripped seats at a salvage yard, a whole seat is about $22, includes the motors and right angle gear boxes, etc. Of course there are dismantlers you can purhase from, they might have a larger variety in stock. The motors look similar to ones in my old Mercedes.
Old Aug 13, 2011 | 12:35 AM
esievel's Avatar
3rd Gear
Thank you for the input. I wouldn't mind using a drill to turn it for a short term solution. That would actually help a lot. I have a manual for the vehicle but it doesn't really explain the motors for the seats etc. where is that info available?
Old Aug 13, 2011 | 04:40 AM
Might look in more current versions in the RAVE download. The body repair manual has some stuff on removal of the seat base, etc. But it was not very complicated when I worked on my seats, I think they just unscrewed from the end of the motor, inside the cable looks like an old skool speedometer cable. One other forum I looked at had an owner using a hand drill, certainly use something variable speed, dead slow, and if your drill is so equipped, set the chuck clutch for lower setting.
With respect to dust ingress, if you can identify the sensitive part (example - a motor), perhaps it could be wrapped with a very fine mesh that would still allow some air flow, but hold down the soil. Something like lady's pantyhose.
Old Aug 13, 2011 | 04:56 AM
Forgot to mention - could also be the electric switch set that controls the seat. In the Disco these are open frame switches, not sealed against the environment. The same factory makes the ones for Mercedes. The rocker style have some small ball bearings in them. I took mine apart, but did so in a large plastic pan, the bearings can go everywhere. Clean up the contacts with a brass wire brush, contact spray was not enough.
So you might be able to make the seat move by jumping out the particular switch with a short wire.
Next time I was prowling the salvage yard I got a couple and put on my spares shelf ($3).
Old Oct 25, 2012 | 03:39 PM
LRchick's Avatar
I was thinking the same thing also about just changing the seats from the motor to manual because it is easier to handle. What did you end up doing leaving it? Modifying? Please your input will help me decide if I should take that next step to fix my seats. Both driver and passenger motors are out but the one I care for the most is the driver because I want to feel comfortable when driving. Thanks.
Old Oct 28, 2012 | 09:55 PM
Rovin4life's Avatar
check the seat fuses underneath the seats. There are three of them and two of them are three amps. make sure all work.
Old Jan 21, 2013 | 01:03 PM
JesseTalley's Avatar
This is something I was wondering about too, is there any way to convert to manual seats?
The only thing I could think of was to switch out the seats altogether. Maybe another vehicle that I could take seats from, or aftermarket seats?
This isnt a big deal for me, as my electric seats work fine, I just dont like electric seats in general. I wish the land rovers didnt have them.
Old Jan 21, 2013 | 01:33 PM
LRchick's Avatar
JesseTalley,
I havent done my seat even though I have been wanting too. I have been dealing with other things in my Rover like the alternator and some hoses I had to replace because it got pretty cold out here.
I am sure that you can actually do it, I posted the question on a thread a while back and here are some replies I got back hope this helps.
https://landroverforums.com/forum/di...l-seats-53798/
Old Jan 21, 2013 | 08:15 PM
On the D1s you seldom find nice driver seats in the boneyard. But you can use two passenger seats like I did, they bolt right in.
