Rear Tire Carrier CB Antenna Mount
Old Jul 18, 2012 | 10:31 AM
grandkodiak's Avatar
Thats rather low, with alot of metal in the front left section of the antennas "view"... id atleast try to get 1/4 of the antenna over the roof line, on the roof is definatly the best as it would also act as a somewhat decent groundplane. you could also get a lip mount and put it on the hood where a "stock radio" antenna would be on most cars and run the wire under the back lip of the hood... i have a vhf/uhf antenna like that now as i already have a cb on the spare tire carrier (which i dont evne use anymore)... looks stock, and can use the hood as a directional groundplane to the left, right or front depending on where you stick it, and open on the other lol
https://landroverforums.com/forum/au...your-lr-47204/
have some pics of my setup there... ive since coated the stupid chrome lip mount in black undercoating so you dont even notice it!
Old Jul 19, 2012 | 10:04 AM
JohnF's Avatar
5th Gear
The hood doesn't make a good ground plane as it is not metal.
I am a ham and I have a center loaded antenna so the ground plane is less important. I have chosen a lower mounting point so I won't lose it to a tree. It is a compromise.
Old Jul 19, 2012 | 10:43 AM
fiberglass then? though it was aluminum haha. never drilled through it, just tightened bolts on it
Old Jul 23, 2012 | 03:41 PM
honda50r's Avatar
Originally Posted by JohnF
How about a mount that fits in place of the rear bumper trim piece that pops off all the time? That would be out of the way of the door and airflow.
That's me!
Coax runs cleanly under rear bumper, up behind tail lamp assembly, and is tucked underneath stuff all the way into my CB. As you can see, CB is mounted right beside driver. I love it.
Plus, we only use CBs off road anyways? Who cares if mine only gets out a mile or so? Also, I'm only running a four watt CB.
jamestfl
Apr 22, 2014 03:08 PM
Spencerfitch
Nov 28, 2010 06:36 PM
humroot
Jun 20, 2008 08:19 PM
willlane
Nov 19, 2007 09:21 PM
KWLR3
Dec 21, 2005 10:02 PM
