2017 Discovery with lift and 285-50-20 tires
Old Jun 19, 2017 | 07:10 PM
Johnson Rods's Avatar
LR Forum Vendor
Default 2017 Discovery with lift and 285-50-20 tires
Worked with Land Rover dealer on this new Discovery below:
285-50-20 Nitto Terra Grapplers G2 (31.22)
Graphics and anti-glare shield
1.5 inch lift
Ready for the trail with more ground clearance than the LR4.
Old Jun 20, 2017 | 04:35 PM
pendergastjm's Avatar
Very nice!
Old Jun 28, 2017 | 08:09 PM
Tim Mead's Avatar
6th Gear
Awesome! Do you have an ETA for selling the Johnson Rods for the LR5?
EDIT: Nevermind, I see you're now selling them, great!
Old Jun 30, 2017 | 03:38 PM
LR Forum Vendor
Here is another dealer build with a Johnson Rod 1.5 inch lift, 275-55-20 DuraTrac mud terrains (31.9 inches), roof rack and black powder coated wheels. Trying to get some more mods such as a safari rack, sliders and winch. Will post new photos as they get built. The mud terrains look great on this D5.
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Jul 6, 2017 | 02:53 PM
samroy92's Avatar
Thanks for posting these man! I am excited to see more so definitely keep us updated. Planning on going higher on the lift kit? Say 2.5"?
Have you experimented with bigger tires, clearance, rubbing?
Thanks!!!
Old Nov 9, 2017 | 02:49 PM
LR Forum Vendor
Default Discovery 5 with 275-55-20 and Johnson Rod Lift
Here is another Land Rover dealer with a Johnson Rod lift kit installed on a new Discovery 5 with 275-55-20 Duratracs.
__________________
Old Dec 14, 2017 | 11:38 AM
zzeuzz's Avatar
hello
what you think, will 275/60 r20 also fit with the 1,5 lift kit?
thanks
Old Mar 16, 2018 | 06:18 PM
LR Forum Vendor
No, I believe that would be too big at 33 inches.
The 275-55-20 seems to work well around 32 inches.
Here is a picture of a D5 towing with the lift kit and larger tires.
Owner says it works great.
Discovery 5 towing with 1.5 inch Johnson rod lift kit
__________________
Old Mar 10, 2019 | 10:23 AM
scout800's Avatar
4th Gear
[QUOTE=Johnson Rods;610591]Here is another dealer build with a Johnson Rod 1.5 inch lift, 275-55-20 DuraTrac mud terrains (31.9 inches), roof rack and black powder coated wheels. Trying to get some more mods such as a safari rack, sliders and winch. Will post new photos as they get built. The mud terrains look great on this D5.
Is there any rubbing whatsoever with this setup?
Old Mar 11, 2019 | 11:21 AM
Black 18 Disco's Avatar
Running 275-55-20 Cooper Adventurer ATs with no lift on Redbourne 20x10 rims. When first installed, I locked it down to entry height and drove it around in the parking lot with a very minor rub when the wheels were turned to the locks. It was rubbing on the vents at the front of the wheel well and it is very minor, but may be more noticeable with a more aggressive tread pattern and each tire, although the same size, may actually measure out differently. I was going to dremel off the plastic vents at the front of the wheel well, but after 5,000 miles is has not been a problem and I'll leave it alone. At normal driving height it does not rub. Moving to this tire size gives you lots of tire choices, especially in the AT category. Best of luck
