2020 Disco V not locking
Old Jun 26, 2023 | 06:17 AM
disco5-wg's Avatar
Originally Posted by RyanLR3
Try locking your doors, walk away and set the key fob down somewhere away from the vehicle far enough where it's not sensed. Go around try opening the doors. The one that isn't locked and opens is your problem latch assembly.
I did try this. All doors are locked. I also sprayed WD40 in each assembly.
I believe it’s a sensor issue more than a mechanical one. I keep getting hung up on the fact that the rear gate is indicating an incomplete open every time I open it. I’m wondering if it’s the rear gate actuators? I don’t know where the sensor is to detect rear gate closure.
Old Jun 26, 2023 | 07:22 AM
RyanLR3's Avatar
Are you able to change the rest gate opening height by opening the gate to a position somewhere between closed and fully open? Hold the close button until you hear a beep and it should be set to that height. Just curious if that still works.
Old Jun 26, 2023 | 08:23 AM
disco5-wg's Avatar
Are you able to change the rest gate opening height by opening the gate to a kennel somewhere between closed and fully open? Hold the close button until you hear a beep and it should be set to that height. Just curious if they still works.
Yes - that did work and it eliminated the triple beep at the top of the gate open. Unfortunately it did not resolve the root issue. I'm going to give the dealership a call today and see what they say.
Old Jun 26, 2023 | 09:55 AM
socal927's Avatar
Happened to mine 2 weeks ago, trunk looked like it closed completely but I was getting the same "door ajar" alert. Took it to the dealer, and it turns out to be a faulty latch. Same day turnaround.
Old Jun 26, 2023 | 09:57 AM
disco5-wg's Avatar
I have an appointment w/ dealership tomorrow. Fingers crossed it's as quick a resolution.
Old Jun 27, 2023 | 08:05 AM
disco5-wg's Avatar
Just got the diagnoses back from dealership. The right front passenger door latch was faulty. Replacing under warranty. Thanks for all of the input and help in troubleshooting!
joel4507
Freelander
Mar 15, 2023 01:18 PM
joel4507
Freelander
Mar 14, 2022 05:09 AM
tbdiscovery
Mar 29, 2019 08:06 AM
reddiscovery2
Nov 24, 2012 08:51 PM
demonlarry
Jul 18, 2011 09:11 PM
