7-pin trailer connector cover broken = $1200
Old May 11, 2021 | 01:07 AM
asmith's Avatar
Angry 7-pin trailer connector cover broken = $1200
The cover to the 7-pin factory-installed trailer electrical connector broke off the 2nd time I used it. It's hinged at 2 weak points of the plastic - great rugged Best-4x4xFar design .... not. Dealer wants $1200 to replace the entire tow package. No warranty replacement as user broke it.
Does anyone know the original vendor that they use at factory? There's only a LR logo on the cover and nothing on the body of the connector. I bought one off Amazon but the hinge not compatible with the body on the vehicle.
Otherwise I'm going to be busy with Fusion360 and a 3D-printer .... will share CAD here if that ever happens.
P.S. I'd go without the cover but it is needed to retain the trailer connector, for some designs of connector at least :-(
Old May 12, 2021 | 12:27 PM
airrage's Avatar
4wd High
Mine broke similarly yesterday at the hinge. I managed to get the cover back on (held only by the clip).
Old May 12, 2021 | 07:33 PM
asmith's Avatar
Smile Replacement trailer connector cover found
After playing a couple of rounds of Amazon-roulette, I found that the cover from this connector fits fine: "CURT 55415 Replacement 7-Way RV Blade Connector, Factory Tow Package and USCAR Socket Required"
Amazon Amazon
You have to use the original well-rusted steel hinge pin and the CURT spring which is not quite right but works well enough (not yet road-tested - don't throw away the alternate parts just yet ...).
Thanks for listening!
[QUOTE=asmith;773562]
Old Sep 19, 2024 | 08:45 PM
AZ_Broker's Avatar
[QUOTE=asmith;773897]After playing a couple of rounds of Amazon-roulette, I found that the cover from this connector fits fine: "CURT 55415 Replacement 7-Way RV Blade Connector, Factory Tow Package and USCAR Socket Required"
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
so how this worked? Mine broke in the last couple weeks and I just started looking for a replacement.
Old Sep 20, 2024 | 08:30 AM
asmith's Avatar
This repair has worked fine so far - hasn't fallen off yet. But, as noted elsewhere, we've moved to an old F-350 diesel as our main tow vehicle now so the Discovery tow connector doesn't get the use it did a few years ago.
Old Sep 20, 2024 | 10:52 AM
RyanLR3's Avatar
I posted a while back a very good option for swapping over the cover. Pollack is an OEM supplier. This unit is more sturdy. Has a nice connector pin function diagram on the cover as well.
https://landroverforums.com/forum/ne...hit-me-115561/
Mo 3
Feb 15, 2019 09:56 PM
DiscoCam
Jul 27, 2016 11:10 AM
KlamathMatt
Nov 16, 2015 01:27 PM
ejag42@mac.com
Jan 18, 2013 05:55 PM
tooltech
Oct 17, 2012 11:29 PM
