Discovery detects trailer with 4 pin plug but not 7 pin
Old Sep 17, 2024 | 12:03 PM
DWG's Avatar
DWG
3rd Gear
Default Discovery detects trailer with 4 pin plug but not 7 pin
Hi there I recently bought a 2017 Discovery which I plan to use as a tow vehicle for a 1977 Airstream. When I connected the Airstream to the Discovery with the 7 pin wiring harness all of the electronics on the trailer work but the Discovery does not recognize that a trailer has been connected. If I connect a set of magnet lights with the 4 pin plug the Discovery recognizes that a trailer is connected. I am a bit puzzled why the Discovery detects the 4 pin connection but not the 7 pin. I know there is a lot of comments about tow vehicles not detecting led lights because they don't draw enough power but my 1977 trailer has incandescent lights so I don't think that is the problem.
As a temporary solution I have connected both the 7 pin and 4 pin at the same time. The Discovery detects the trailer, signal lights, brake lights, brakes and auxillary line work but for a reason I don't understand the running lights don't. A reasonable solution other than the fact that I would not be able to tow at night.
Anyone have any idea how to resolve my problem?
Old Sep 17, 2024 | 08:05 PM
RyanLR3's Avatar
I'm guessing your Airstream has LED lights and your magnet lights are incandescent.
Old Sep 20, 2024 | 03:28 PM
DWG's Avatar
DWG
3rd Gear
Hi Ryan,
My 1977 Airstream has incandescent lights. In the Disco manual it states that the minimum load for Brake/Signal lights is 1.75a / 21W. Not sure if it is possible that the incandescent lights on the trailer are lower than the minimum. I thought that most lights that are not LED would be similar.
Old Sep 20, 2024 | 03:44 PM
RyanLR3's Avatar
Originally Posted by DWG
Hi Ryan,
Yes, 21W is pretty standard for a 12V turn/stop lamp. Might be worth checking the bulb type and your connections.
flybd5
LR2
Aug 29, 2020 10:40 PM
racoco
Oct 27, 2015 12:54 PM
mark d
Apr 11, 2013 01:03 PM
RoveringAgain
Jun 11, 2009 02:53 PM
jbriggs
Aug 6, 2007 12:02 PM
