Adding Overland Lights / Power access
Old Mar 21, 2022 | 02:56 PM
1979rover's Avatar
Originally Posted by Ronbo44
The lamps are Baja Designs - S2 - 2450 lumens ea. Look closely they’re mounted upside down on the license mounting frame - Amazon - (black aluminum), quite rigid and doesn’t vibrate. No cutting into the grill. The wiring is snaked past the fan housing to the take off + post and - ground. Controlled wirelessly. No cutting into vehicle’s wiring and voiding any warranty leftover. Just make sure you shut off - wirelessly. It works great.
Ah, I see it now! Nicely done.
Unfortunately I don't have a front license plate, lol.
Old Mar 24, 2022 | 04:14 PM
tribeoverlandatx's Avatar
7th Gear
Lift up the cap on the + which is your positive. Your negative goes to the stud which is sticking up. Be sure to wire in a fuse to protect the lamps. Good luck.
I understand the + under the cap, but thats just a charge post. I am looking to connect to it and cannot find a clamp that is the right fit.
Looks like you wired directly into a positive 12v on the harness?
Hughbullen
LR4
Nov 11, 2015 09:26 AM
jLR4
LR4
May 15, 2013 10:09 AM
BD_LR4
May 14, 2013 11:11 AM
ICECREAMEATER
LR4
Jan 29, 2013 09:08 PM
jLR4
Apr 8, 2012 03:35 PM
