Brake Fluid Flush Process
Hello all! I have acquired some 6-piston calipers from a 2018 L405 that I am getting ready to install on my 2018 D5 TD6. Thanks to the excellent thread from AirRyan, I've got the parts ready to go. I'm sticking with OE brembo rotors and the Powerstop Z36 pads.
My question pertains to the brake flush/bleed. Can you use the traditional method with a Motive power bleeder or do you have to use the electronic process via Topix? I've got the Launch CRP 909 which seems to include the brake bleeding option. I'd rather stick with the mechanical process for simplicity, but I also want to ensure the job is done correctly.
Thanks in advance!
Thanks in advance!
