Cooling System D5 Si6
Old Jan 7, 2024 | 12:03 PM
ponderosajack's Avatar
Default Cooling System D5 Si6
I'm getting ready to do a coolant drain and fill which I've done before.
How do I know if I have the older upper and lower coolant outlet pipes (are these what are also called crossover pipes?).
I understand that the upper and lower coolant outlet pipes were redesigned due to weakness in the plastic welds.
There's a Technical Buletin: JTB00566NAS4 dated 23 MAY 2018 that addresses this issue (attached) but not necessarily the D5.
Replacing the lower pipe looks to be fairly involved, removing the supercharger, intake manifold, and throttle body.
Looks like replacing just the upper pipe is fairly easy.
Since my D5 is a 2017 maybe it has the new pipes - it takes JLR a long time to issue a bulletin after they figure out a fix.
I know this was an issue on the LR4 also. Is it an issue on the D5?
Old Jan 10, 2024 | 11:52 PM
Donc98's Avatar
New style on the left. Don't forget about the rear cross over pipe as well. The fronts are now available also in aluminum on ebay or Amazon. I picked up one during the prime day sales as a backup.
Old Jan 11, 2024 | 11:28 AM
That picture helps. Thank you
timboslice59@gmail.com
Jun 4, 2024 04:37 AM
Brandon318
Jan 19, 2022 11:42 AM
Brandon318
Jan 12, 2022 08:36 PM
Loriebluedico5
Apr 18, 2020 11:56 PM
keninnc
Nov 17, 2019 10:32 PM
