Disco 5 - Replacement Sunroof Drain Tube
Old Aug 1, 2024 | 04:30 PM
Chucktastic's Avatar
Thanks for that! The parts diagram shows a LH and a RH drain so I assume there's another on the battery side where I initially started looking. Where you show on the LH side is a bit further forward than I initially started looking on the RH. This should help a lot!
Old Sep 29, 2024 | 02:21 PM
markbrads's Avatar
Hi Richard,
Had the water run to the front footwells of your car and were the back footwells always wet?
Thanks.
Mark
Old Sep 29, 2024 | 04:23 PM
RichardinFL's Avatar
Hi @markbrads
YES, when we get heavy rain, the water used to come all the way to the front. That is how I found out I have a leak.
When we get heavy rain or a tropical storm water would accumulate unnoticed under the 3rd row seats. Once I start driving, water would move to the 2nd row seats footwell, then to the front.
Old Sep 29, 2024 | 04:29 PM
markbrads's Avatar
Hi Richard,
Thanks for coming back to me and confirming, I'm going to check under the 3rd-row seats tomorrow. Did you replace both sides or is there only one side to check and fix?
Quite unbelievable isn't it for a £65k product and Land Rover doesn't give a damn from the comments I've seen on most forums.
Thanks.
Mark
Old Sep 29, 2024 | 10:40 PM
Hi Mark,
I traced the source of the leak to only one side. The other side was not leaking, so I did not touch it.
Land Rover SUCKS!
Richard Gallant
Feb 23, 2026 06:09 PM
autoarcheologist
Apr 23, 2024 03:39 PM
MaineLR3
Sep 2, 2023 03:43 PM
dustinkantu
Nov 16, 2016 03:19 PM
Frank4
Jul 31, 2016 09:05 AM
