Extractor vs oil drain for TD6
Has anyone actually compared to see if the drain plug actually drains out more oil than extracting it because they seem to be at the same level if anything the siphon might even be lower, has anyone noticed a difference since I just invested in a mityvac and am trying to reduce going under the car and dropping the skid.
Ditto.
I use an extractor. When I refill the amount it calls for, the oil level is always good, so I'm satisfied. Easiest oil changes I've ever done! However, the skid plate was very easy to remove/replace when I did trans/diff fluid changes.
whostorm05
Range Rover L322 (3rd Gen)
Dec 1, 2019 08:19 PM
