front hood will not pop open
Old Feb 18, 2024 | 11:28 AM
  #21
sea2mtn's Avatar
Question 2020 Discovery Hood Latch Release Failure
Originally Posted by jhouser
I had this issue before and the dealer could not find issue with the hood latch release malfunctioning. Today the battery died and the hood latch release will not open both sides of the hood to allow me to release the hood and open it. The hood release will pop one side open but not the other. Does anyone have experience with this or suggestions?
My hood latch release appears to work on the driver (left) side, but not the right (passenger side) and I'm unable to open the hood. Did anyone find an answer to this riddle from a dealer of other triage? Thanks. Seattle
Old Feb 18, 2024 | 11:31 AM
  #22
RyanLR3's Avatar
I don't have a fix but mine does the same sometimes. I pull harder and it works. I need to get on with replacing the release cable.
Old Feb 18, 2024 | 11:55 AM
  #23
1979rover's Avatar
I was told that the cables stretch and can cause one side to release easier than the other.
mine is this way currently. To open it I pull the latch higher than usual by pulling up to the OEM stopping point, then continuing past it by pulling inward and up.
Old Feb 18, 2024 | 03:11 PM
  #24
ponderosajack's Avatar
Try having someone push down on the hood on both sides above the latches while you pull the release lever.
Old Feb 18, 2024 | 09:43 PM
  #25
BritCars's Avatar
Yes. That works for mine
Unfortunately I don't think it's the cables. I had mine adjusted and then replaced on warranty. But it still has an issue. Now they say the latch mechanism is rusted and needs to be replaced. But I'm a long way out of warranty and had this issue since new so I'm skeptical and decided not to spend the $$ to test that theory..
I just have someone push the hood down while I wiggle the release lever and that seems to work.
Old Feb 19, 2024 | 03:36 PM
  #26
ar077's Avatar
Originally Posted by 1979rover
There is a TSB on the hood latch cable stretching. I've had this happen twice.
Any chance you can provide a link to the TSB or attach it in a reply to this thread?
Old Apr 19, 2024 | 04:04 PM
  #27
bparker240@gmail.com's Avatar
Default Complaints.
Having the same issue here and the dealer wants to smash the grill to be able to access it which is $1k just for the part. That we’re on the hook for that they put a bulletin out about. How the F#%! does that work? Though I have done enough research to know that this problem is VERY common. If we all file a complaint with the NHTSA then there’s a chance we can all get it covered under a recall. That way it’s no longer our headache and is back on Land Rover.
Old Sep 27, 2024 | 08:25 PM
  #28
Wrooker's Avatar
Default Question
[Did you get a solution to this i have the same problem and i was told tbey may have to smash it in for 1-2k
QUOTE=bparker240@gmail.com;896569]Having the same issue here and the dealer wants to smash the grill to be able to access it which is $1k just for the part. That we’re on the hook for that they put a bulletin out about. How the F#%! does that work? Though I have done enough research to know that this problem is VERY common. If we all file a complaint with the NHTSA then there’s a chance we can all get it covered under a recall. That way it’s no longer our headache and is back on Land Rover.[/QUOTE]
Old Sep 27, 2024 | 08:26 PM
  #29
Wrooker's Avatar
Did you get a solution to this is was quoted 1-2k for smashing ina nd replacing a locked hood. There has to be a better option right?
Old Nov 4, 2024 | 04:37 PM
  #30
damaja's Avatar
5th Gear
My hood release lever went from "pull all the way or with someone pressing on the hood" to "there appears to be no tension anymore". I think something let loose.. perhaps in the lever itself, could something have stripped?
In any case, there appears to be no way to open the hood from the inside. Is there an alternate, yet painful way to release the hood? Like going in through the wheel well or something else?
