Front and Rear Diff fluid change, also transfer case fluid change
Old May 13, 2023 | 06:02 PM
gmfain's Avatar
Default Front and Rear Diff fluid change, also transfer case fluid change
My rig hit 80K. So time to change diff and transfer case fluids.
Leveled the old girl up. laid out the respected fluids in location.
6 ton jack stands, not harbor freight. LOL
Level check
rear fill plug, 8mm allen
rear
rear 3/8 square drive
rear plug, little metal on magnet, pretty normal.
rear
front diff
front 8mm hex plug also
front 3/8 square drive
front plug
front plug, again normal amount of metal
front draining
muddy shield shows no leaks
transfer case, you can see the small heat shield you need to remove.
transfer case draining.
I used a small cheap pump to refill them all. I filled till they ran over.
Old May 15, 2023 | 09:28 AM
1979rover's Avatar
Great info and detail, thanks!
How difficult was it to get the underbody shield off?
Old May 16, 2023 | 04:37 AM
gmfain's Avatar
Not difficult at all. I remove it every oil change too. Personally, I like to inspect everything under there.
Old May 16, 2023 | 01:16 PM
ar077's Avatar
As usual, gmfain knocks it out of the park!
What guidance did you use for changing the fluids at 80k miles? What are the required differential and transfer case fluids? Have you changed your transmission fluid or, if not, when will you do that?
Old May 17, 2023 | 01:17 PM
gmfain's Avatar
My mechanic recommended 80k diffs and transfer case.
He recommended 150k for transmission, unless heavy towing. 100k
Old May 17, 2023 | 01:33 PM
ar077's Avatar
Sounds like good advice. I'll use those numbers.
Old May 17, 2023 | 07:29 PM
gmfain's Avatar
I am thinking 90 or 100k, sounds safer to me.
Old May 18, 2023 | 02:18 PM
ponderosajack's Avatar
Note that you can check if vehicle is level using dashboard offroad display.
Old May 18, 2023 | 05:33 PM
gmfain's Avatar
I realized that after the fact...lol....sometimes I'm just old school.
Old Jun 7, 2023 | 11:29 PM
mtaylo32's Avatar
Nice!
How many quarts of gear oil did you buy for the diffs and transfer case? With an electronic rear locker does it require different spec'd fluid like some of the older models? I think I saw a fluid spec sheet floating around on here, but can't seem to find it now.
Thanks in advance!
