Front and Rear Diff fluid change, also transfer case fluid change
Old Nov 24, 2024 | 01:50 PM
  #21
gmfain's Avatar
Disco 2???
Old Nov 24, 2024 | 08:05 PM
  #22
quirozson's Avatar
Originally Posted by gmfain
Disco 2???
? 2022 R Dynamic
Old Nov 25, 2024 | 05:02 AM
  #23
gmfain's Avatar
Originally Posted by quirozson
? 2022 R Dynamic
I'm sorry I meant Disco Sport? Air suspension?
Old Nov 25, 2024 | 08:08 AM
  #24
quirozson's Avatar
?…. it’s the exact same car you have just a 2022 year model… P360 Disco V
Old Nov 25, 2024 | 01:51 PM
  #25
gmfain's Avatar
My 17 seems to be very different. puzzled? Does yours have a low range?
Old Nov 25, 2024 | 02:02 PM
  #26
quirozson's Avatar
Yes it does have Low Range.
Old Nov 25, 2024 | 02:17 PM
  #27
gmfain's Avatar
I mean, I see three possible drain plugs. It almost looks like a Haldex unit.
I'm still researching..... send me the vin.....I'm not giving up.
Old Nov 26, 2024 | 07:36 AM
  #28
gmfain's Avatar
Do you have any pictures from the front angle? the pics you posted appear to be from the rear angle.
Old Nov 26, 2024 | 09:51 AM
  #29
CincyRovers's Avatar
Disco 5 went to the Active Driveline (iAWD) when the facelift came for the 2021MY. The transfer case is completely different, and the infinitely-variable locking center differential has been replaced by an electronically-controlled clutch pack that mimics the old center diff, and has a variable torque split that can send as much as 50% of the torque to the front axle. It can also completely disconnect the front axle and bring the front propshaft to a complete stop while driving in certain situations to increase fuel economy. It is always AWD when driving from a stop, under 21 mph, over 100 mph, at temperatures below 37°F (3°C), and if you're off-road. The system is also proactive, so whether your lights & wipers are on will affect the AWD system's operation.
Another benefit of this new system is if you break your front axle, you will still be able to get back to pavement and drive home, as the torque is always sent to the rear. Hell, you can still drive the vehicle if you remove the front axle. If you broke any axle on the old system, you wouldn't be able to move.
Old Jan 3, 2025 | 05:31 PM
  #30
adam5's Avatar
I used all Ravenol fluids from Blauparts. Never had any problems with that brand .
Thanks @gmfain for posting the instructions!
I ordered Ravenol stuff today, from blauparts; planning on changing all the driveline fluids at 50K miles.
Ravenol Gear Oil VSG 75W-90 1L
SKU: J1C1109 1x $21.95
Ravenol Differential Fluid MDL Multi Disc Locking 1L
SKU: J1C1126 2x $53.90
Ravenol Transfer Case Fluid TF-0870 / DTF-1 1L
SKU: J1C1125 2x $71.90
Also found on-sale ZF OE service kit from FCP: $216
