Gap iid tool
Old Nov 21, 2024 | 11:04 PM
  #21
462disco's Avatar
Originally Posted by WernerDisco
Any update on this one? Seems to have the same, everything is active but cannot activate Dynamic mode
Tx
Just thought of something today..
What trim level is your Disco? I have an SE and it's not taking the dynamic settings. Perhaps the HSE has different settings that allow Dynamic mode to work.
EXAMPLE.. SE trim level does not have auto tilt mirrors in reverse.. I had to enable mirror tilt, AND memory seats CCF to enable the mirror tilt (SE has no memory seats).
I'm wondering if there's another CCF setting that needs to be enabled (that HSE might have on) for dynamic mode to work on the SE.
Old Nov 22, 2024 | 11:30 AM
  #22
Chucktastic's Avatar
I was wondering the same as well. There also seem to be a lot of differences between 2017 and 2018 CCFs. I'd love to see a CCF from a fairly well equipped 2018 HSE. As far as our HSE Lux goes, it doesn't have much beyond the cold weather package in terms of additional options.
Old Feb 2, 2025 | 08:56 PM
  #23
WernerDisco's Avatar
5th Gear
I have a 2020 Landmark edition.
I have played around with all the CCF's but I cannot get it to select Dynamic mode.
I can see it on screen and all the functions is there, just cannot select the Dynamics mode
Werner
Old Feb 2, 2025 | 09:15 PM
  #24
If you wouldn't mind a CCF swap I can send you my settings. I can select dynamic mode on my 2018 HSE. I also swapped my terrain response selector that has the "auto" LED on top. That may or may not be required.
Old Feb 2, 2025 | 09:30 PM
  #25
5th Gear
That would be great, I will compare and see what is different.
Old Feb 2, 2025 | 10:29 PM
  #26
5th Gear
Sent,
Please send what you have enabled TR2, auto locking when walking away etc..
Thank you!
Old Feb 7, 2025 | 08:17 AM
  #27
maviaman's Avatar
Sent,
Thank you!
Hi, got a 2017 first edition and it dosn't support walk away locking (I can unlock it with key in pocket, but not able to lock) or remote start from App, Can we get these updated through CCF - O acquired a G4 tool.
Old Feb 9, 2025 | 04:55 PM
  #28
cozmo920's Avatar
3rd Gear
Tx
I just made the same changes on my 2020 Discovery HSE, everything appears to show up, but can not activate Dynamic mode, so none of the dynamic configure options are available to change. However G meter and other options function. Is there any new insight on how to enable dynamic mode?
Old Feb 9, 2025 | 05:01 PM
  #29
cozmo920's Avatar
3rd Gear
Default Adding Massaging seats to 2020 D5
I am starting another experiment. I am trying to add front massaging seats to my 2020 Disco. Has anyone done this? They should just drop in, and the configurations appear to be available in CCF with the gap tool. TBD if all of this will work. My new seats are still in transit, I have been preemptively trying to get the massage option to show up in the infotainment and seat controls. No luck so far, but I have started receiving a fault of no massage module present. So hopefully when I plug the new seats in everything will just start working... I doubt it, but hopefully it will. New seats should be arriving by the next weekend.
Old Feb 9, 2025 | 05:19 PM
  #30
5th Gear
I can select Dynamic mode on the dial, but the infotainment screen does not recognise the car is in Dynamic mode so I cannot change any of the dynamic settings, quite frustrating..
On the 4x4 screen it recognises the dynamic mode enabled, but not when I want to customise the settings. All of the settings is currently on comfort mode, so only difference it makes is the red dials on the dash
