How often do you change a TD6 fuel filter?
Old Jul 29, 2022 | 05:14 AM
ToiletDuck's Avatar
Default How often do you change a TD6 fuel filter?
I’m at 53k miles on my TD6 and starting to wonder when I should crawl under and swap that guy out.
Old Jul 29, 2022 | 11:14 AM
whammie's Avatar
4th Gear
Fuel filter is accessed from the top, not underneath. Also, it should be changed every other oil change. At 50K plus miles it should have been changed out at least twice.
Old Jul 29, 2022 | 09:44 PM
Seattle TD6's Avatar
I do mine every 15k miles. You should definitely do it with 53k on your car and then every 10-15k miles.
Old Aug 1, 2022 | 05:23 AM
gmfain's Avatar
I change at 16K, every other oil change.
Old Aug 9, 2022 | 05:45 AM
dgardel's Avatar
I change it every 2 oil change (I change oil every 10000 km)
the
Old Feb 27, 2024 | 09:16 AM
Georgiastar12's Avatar
Default Part Number
I have a 2019 Discovery TD6. Do you happen know the part number for the fuel filter I'm trying to make sure i order the right one.
Old Feb 27, 2024 | 12:57 PM
sowrco's Avatar
I do mine every 20K - maintenance schedule says every 32K. I use the Mahle filter from Rock Auto.
Old Feb 27, 2024 | 02:09 PM
mtaylo32's Avatar
@Georgiastar12 You can purchase the Mahle filter from RockAuto.com: https://www.rockauto.com/en/moreinfo...=6200&jsn=1728
The part number is MAHLE / CLEVITE KL1044
This one works just as well as the factory fuel filter. If you prefer OEM, the LR part number is LR041978, but is 2-3x the price of the MAHLE filter.
Badcuda
Range Rover Evoque
Aug 2, 2019 05:50 PM
discoguy96
Jun 26, 2012 10:27 PM
Pickup Man
Apr 12, 2011 11:46 AM
targotsi
Jan 22, 2009 11:39 PM
jezzadog
May 10, 2006 10:23 AM
