How to trickle charge Battery in Disco V?
Old Feb 5, 2019 | 10:26 AM
longtrip68's Avatar
Originally Posted by ponderosajack
I tested it out today:
Drove D5. Parked. Pressed Start/Stop button once to turn off engine. The radio continued to run for 9 minutes, then gave a message it would shut down in 1 minute, and it did shut down at the 10 minute mark.
I pressed the radio power button once. Radio came on for 9 minutes, gave message it would shut down in 1 minute, and it did shut down at the 10 minute mark.
I repeated this 2 more times and got it to run for a total of 30 minutes. I believe it would have repeated more iterations but I had to start the D5 to run an errand.
I don't see this procedure to be a problem if you want to listen to the radio while parked. I believe most modern vehicles will turn off the radio after an amount of time.
Thanks for the update. Good to know. I had the battery tender on the posts under the hood the other day, plus some driving around and all is well.
escott16
Jan 10, 2019 06:09 AM
aemnky606
Jun 4, 2017 11:36 AM
Chris Schafer
Jun 6, 2016 12:32 AM
Rufflyer
Dec 21, 2014 09:26 PM
LR03NJ
Nov 12, 2012 03:16 PM
