leaking rear locking differential $5900
Old Oct 10, 2024 | 02:00 PM
delly44's Avatar
Default leaking rear locking differential $5900
i have a 2019 Discovery5 with a leaking rear (locking) differential. it is leaking from the seal on the front of the unit where the prop shaft (drive shaft) connects to the differential. local dealer telling me there is no seal available for this unit so the entire unit must be replaced at cost of $3800 plus $1900 for labour. anyone have this problem or know of a better solution?
2019 Discovery with Locking rear Differential
TD6
115kms (71k miles)
leaking seal
Old Oct 10, 2024 | 02:08 PM
gmfain's Avatar
Holy cow!
Try sourcing part from Canada or the UK or Germany.
let us know!
?? might call these guys https://www.landleaping.com/oem-part...VkIFByb2R1Y3Rz
Old Oct 10, 2024 | 11:13 PM
delly44's Avatar
thanks for the suggestion !
Old Oct 11, 2024 | 12:20 PM
Chucktastic's Avatar
There is also a standalone seal for the locking diff.
Old Oct 11, 2024 | 10:19 PM
delly44's Avatar
thanks gmfain and Chucktastic with your help I convinced dealer that I did not need a new differential but only the seal LR174475.
Old Oct 12, 2024 | 08:36 AM
Now you just have to hope they do the job right and set the pinion bearing pre-load correctly. You'll still have a decent labor bill since the rear exhaust and driveshaft have to come out, but a $20 part is definitely cheaper than a $3800 part.
Old Oct 12, 2024 | 09:43 AM
delly44's Avatar
yes you are so right Chucktastic- i have tried 4 different LR dealers in my area none of which give me any confidence. the only saving grace is their warranty on repairs is 12 months unlimited kilometres. The quote for replacing the seal is $1,900 CAD ($1,400 USD). I do the majority of maintenance myself however i need to find a competent independent repair shop to do the work i cannot do on my own.
Old Oct 17, 2024 | 09:44 PM
delly44's Avatar
follow up on the repair. total cost for replacing rear pinion seal was $2140 C$ ($1552 USD). Labour was $1870 plus parts $270 - seal, diff fluid, and exhaust clamp.
Old Oct 18, 2024 | 08:19 AM
That's great! I'm sure Land Rover would've preferred to sell you a new diff so they could refurbish it and sell it to someone else at full cost.
me 2
Nov 8, 2021 12:50 PM
me6067
Dec 11, 2017 09:50 AM
pawright
Dec 27, 2014 09:34 PM
Charlie_V
Oct 8, 2014 09:33 AM
Colorado David
Jul 19, 2014 03:36 PM
