Loud clunk noise when shifting to D or R
Old Nov 11, 2023 | 09:37 AM
Hatem's Avatar
Default Loud clunk noise when shifting to D or R
Hi,
I noticed recently a clunk noise when shifting from D to R or the opposite it happens every time i shift between them, and sometimes when the gear changes at low speeds.
I lifted the car in the shop and checked underneath while charging the gear, i noticed nothing.
i also just changed the transfer case oil but nothing changed.
* the transmission shifting is smooth
model: Discovery 2018 HSE
mileage: 59k (95,000km)
Check the attached video, any thoughts? 🤔
note the clunk sound after the sound of the gear shift.
Old Nov 13, 2023 | 08:14 PM
abran's Avatar
I’ve found the front axles can cause this. On the ground while making the noise look at the axles.
good luck
Old Nov 13, 2023 | 09:21 PM
canon_mutant's Avatar
Sadly could be lots of things. Almost need it SAFELY on blocks and a buddy to shift it while you observe.
Old Nov 14, 2023 | 10:16 AM
abran's Avatar
unfortunately if it’s the axles the wheels need to have a load on them to make the axle noise.
Ive diagnosed and remedied 2 D5s with a clunk while shifting as axles. Doesn’t mean that’s the OPs issue, but easy to diagnose.
Old Nov 16, 2023 | 12:26 PM
462disco's Avatar
Originally Posted by Hatem
Hi,
I get the exact same sound but only when the car is warm. In the mornings when trans temp is low, no clunk.
May not be related, but a transmission fluid/pan change might not be a bad idea as well.
Hatem
Sep 20, 2023 10:20 PM
Hatem
Sep 18, 2023 11:12 PM
the420star
Nov 3, 2022 08:12 AM
algansk
Jul 4, 2018 04:56 AM
fideladio
Oct 15, 2010 06:27 PM
