The mods begin...
Old Sep 12, 2018 | 08:57 PM
  #61
Hayseed_D5's Avatar
Damn this thread... your Pig looks great
Replacing the OEM 22" black ones for a 20" winter set. I found a set of 20" 2013 Range Rover wheels. Getting professionally powder coated black. New TPMS arrive tomorrow. Putting Hakapelitta R3 SUV on there for upcoming winter. After the winter, will go with AT tires. These will be dedicated wheels. May sell my 22" set-up - not sure.
Your speedo is off with the 275/55r20 - did you have the dealer adjust?
Old Sep 13, 2018 | 08:15 AM
  #62
abran's Avatar
I have a friend who is a tech at Land Rover.
He told me you just can’t swap in new sensors, they have to be manually input into the TPMS module.
I have a new set of wheels being powder coated and am planning on swapping over the TPMS, unless someone else has a different experience.
Old Sep 13, 2018 | 09:18 AM
  #63
AzjaST's Avatar
I purchased set of 20' wheels on Ebay, take-offs from 2017 Discovery, including original TPMS and tires. Installed, adjusted pressure and that's all, no other actions necessary. Maybe Range Rover wheels have different model of TPMS?
Old Sep 13, 2018 | 02:00 PM
  #64
BritCars's Avatar
I'm pretty sure the TPMS self learns when you install and drive with them for a bit
Old Sep 13, 2018 | 11:08 PM
  #65
abran's Avatar
Good to know.
Old Sep 14, 2018 | 07:09 AM
  #66
Hayseed_D5's Avatar
Of course, my dealer states that I have to make an appointment and they MUST be programmed by the dealer.
ETA: They also said this reprogramming has to be done each time I switch the wheels between summer and winter,
Old Sep 19, 2018 | 05:44 PM
  #67
bvdave's Avatar
Can I ask what your process was for Plasti-dipping these wheels? And did you cover the tires when spraying?
thanks-
dave
Old Sep 19, 2018 | 07:51 PM
  #68
abran's Avatar
Im going to try with the GAP tool to sync TPMS. I have an Autologic, but they are not supporting the newest models yet.
Old Sep 19, 2018 | 10:47 PM
  #69
ToiletDuck's Avatar
I'm still waiting on mine to get here, hopefully Sunday, but what's the point of TPMS if off-roading or really any other time? If you put on off roaders can't you just walk around for a second and check your pressures? Does the TPMS disable anything if it senses you're low? Like limit your speed or something? Couldn't you use rims without it for when off-roading?
Old Sep 19, 2018 | 11:09 PM
  #70
abran's Avatar
It will give an annoying fault on the dash. That’s it
