P2185
Old Jul 11, 2023 | 06:25 PM
mtaylo32's Avatar
Update: Have replaced 1 sensor myself, code still showed up. Took it into a local mechanic who specializes in European makes, familiar with LR's, replaced the sensor 2 more times with the CEL still showing. Vehicle does not overheat, no temperature fluctuation, drives great. They say it could be tied to a software update or a bad computer, they are unable to perform that work as Land Rover has apparently locked them out from being able to do anything computer/software related to drive business to dealerships as they are losing a lot of money. First I've read of a computer going bad in one of these vehicles. 105,000 miles on my truck. Taking it to another shop next week for further diagnostics and to check in on the computer claim. Anyone heard anything about computers going bad? Any ideas on how expensive that could be?
Old Jul 13, 2023 | 11:03 AM
ToiletDuck's Avatar
Originally Posted by gmfain
I know this sounds crazy, but how old is your battery? Get your battery tested.
Since the code cleared, I would check the battery.
Weak or failing battery will cause all kind of weird stuff.
This! I had a weak battery causing all sorts of issues and have the same exact vehicle
Old Jul 13, 2023 | 11:06 AM
ToiletDuck's Avatar
Go swap the battery
Old Jul 13, 2023 | 11:11 AM
mtaylo32's Avatar
Thanks. I actually think I will today. Report back soon!
Old Aug 24, 2023 | 12:30 PM
mtaylo32's Avatar
This has been fixed. There is a hidden second sensor down near the radiator. If you get this code I would recommend replacing both sensors as it is an inexpensive repair and pretty simple. For the sensor located near the radiator you will be required to drain and refill the coolant system, but the other sensor that is located near the top of the engine can be easily swapped without needing to drain anything from the system. Have put about 2,000 miles on my vehicle since replacing this part and everything checks out. Thanks for everyones help!
Old Aug 24, 2023 | 07:09 PM
timc166293's Avatar
Same issue here. They replaced thermostat and water pump last week. All good so far.
Old Apr 21, 2024 | 12:19 PM
Izanagi's Avatar
Relocated to Discovery 4 page.
Old Apr 25, 2024 | 01:20 PM
adam5's Avatar
Thank you OP for sharing information like this. It really helps avoid surprises for the rest of us.
Old Apr 25, 2024 | 01:26 PM
mtaylo32's Avatar
Happy to help! Not sure if I mentioned above, but this sensor failure seems to be super rare based on my conversations with Louisville LR Parts Specialist.
ToiletDuck
May 16, 2022 03:04 PM
2020Defender
Jan 26, 2022 12:41 PM
Bbg
LR2
May 26, 2021 10:59 AM
jasondm
Feb 5, 2009 02:45 PM
tsuami1
Sep 27, 2007 04:34 PM
