Passenger side brake light
Old Jul 8, 2025 | 09:52 AM
DC2's Avatar
DC2
Default Passenger side brake light
Passenger side brake light stopped working - all other lights in unit are fine. I was then told that I had to replace the whole unit as the brake light is an integrated LED @£447.50 inc vat but no fitting!!!!!!!
I've sourced a second hand one from ebay but would appreciate any guidance on how to replace it, for reference it's not hte section in the back door, rather the rear wing.
Thanks in anticipation
Old Jul 8, 2025 | 10:57 AM
sowrco's Avatar
Pull the trim cover and look inside. There's 2 nuts and a connector. Disconnect the cable then remove the nuts ensuring you don't drop them inside the panel. Switch out the light, test before re-assembly, then snug it all down - don't over tighten. Make sure you get the correct light cluster, there are many versions. I performed a test disassembly/refit so I could get the part number of the light.
Old Jul 9, 2025 | 03:10 AM
DC2's Avatar
DC2
Fantastic SOWRCO, much appreciated!
Old Jul 10, 2025 | 11:28 AM
Elzot's Avatar
As a general suggestion buy from a supplier that will match the part to your VIN. As mentioned above there are often multiple versions of the same part.
Old Jul 11, 2025 | 10:14 AM
sowrco's Avatar
Good idea. Me? I needed to see the actual part number as installed! Plus I wanted to do a dry run because sometimes things break and I didn't want to break the new light.
cappedup
Jan 1, 2023 01:57 PM
Cortney Renae Waguespack
Range Rover Evoque
Nov 27, 2019 11:29 PM
coors
Dec 3, 2015 08:28 PM
jaystekan
Nov 10, 2014 11:06 PM
crznmyway
May 24, 2012 06:34 PM
