Preventative Maintenance
Old Jul 22, 2024 | 05:44 AM
D5Aus's Avatar
Originally Posted by mtaylo32
See if these help @RyanLR3 . I haven't done the procedures yet, but pulled the documents from topix.
@mtaylo32 any chance you can post a copy of the JLR work instruction to replace the fuel pump timing belt please?
Cheers, Geoff
Old Oct 2, 2024 | 10:04 PM
D5Aus's Avatar
@mtaylo32 - would you please be able to pull from Topix the rear belt/fuel pump belt replacement instructions also please? Here in Australia JLR don't allow access to Topix unfortunately.
Thanks so much!
Geoff
Old Oct 20, 2024 | 07:54 PM
RyanLR3's Avatar
I've got another thousand miles until I need to do the timing and fuel pump belts. Does anyone have the fuel pump belt procedure?
Old Oct 21, 2024 | 08:28 AM
mtaylo32's Avatar
@D5Aus @RyanLR3 So sorry for my delay! We just had a baby and have been on here infrequently. I unfortunately did not pull the Topix procedure for the fuel pump belts and did not end up doing the belt procedure on my truck. I chose to not do it when I did the other pulleys, water pump, etc. because of the limited amount of space, the reported failure rate is extremely low, and when folks have replaced it the belt was hardly worn. I will do it eventually, but haven't gotten around to it quite yet. At 121,000 miles on my 2017 TD6 and still going strong. Please let me know if either of you end up doing this. Again, sorry for the delay.
mtaylo32
Feb 26, 2024 06:18 PM
islavov
Feb 11, 2023 11:35 PM
LR disco 5
Jul 29, 2021 12:39 PM
Matthew424
Jul 10, 2021 10:39 AM
SoCalWiley
Dec 20, 2018 08:48 PM
