Proud Rhino Discovery 5
Old Sep 7, 2020 | 03:11 PM
  #31
Ronbo44's Avatar
Default Pdf
Works fine
Thanks
Old Sep 7, 2020 | 11:20 PM
  #32
canon_mutant's Avatar
Originally Posted by ar077
Don't forget the Lucky8 Proud Rhino Rock Sliders.
Like those wheels . . .
Old Sep 8, 2020 | 09:25 PM
  #33
ar077's Avatar
Thanks! They're made by Redbourne Wheels (redbournewheels.com) who make aftermarket wheels exclusively for Land Rovers and Range Rovers. The web site has a fitment guide and a wheel configurator that shows what any of their wheels will look like on your vehicle, right down to the exact vehicle color that was available the year your Land Rover was made.
Old Dec 16, 2023 | 10:14 AM
  #34
sowrco's Avatar
RE: Lucky8 Light Brackets
THANKS! The instructions were super useful. Here's a list of the changes I made to my installation:
1-Added 6mm spacers to the upper inner welded spacers. This enabled a no-drag fit through the lower grill slots.
2-The horn mounting holes were tight - I removed some paint. The holes size is adequate, pre-painting.
3-Exchanged the bolts supplied with high grade partially threaded bolts, M6 x 40mm.
4-Did some different trimming on the soft plastic side baffles, plus a slot for the harness on the marked "R".
Good result after a bit of nurturing.
Old Dec 16, 2023 | 11:59 AM
  #35
ar077's Avatar
Where did you find the 6mm spacers?
Old Dec 16, 2023 | 12:06 PM
  #36
ar077's Avatar
One more question. What lights would you suggest?
Old Dec 16, 2023 | 03:27 PM
  #37
sowrco's Avatar
I ordered the 6mm long spacers from McMaster-Carr, I live in California and they are an online industrial supplier.
I fitted Baja Designs Squadron Sport spot lights. The price was right. Rigid D-Series Pro Spots would be nice too. I originally sourced some very expensive Rigids but thought the better of it.
Old Dec 16, 2023 | 03:52 PM
  #38
ar077's Avatar
Thanks, and Merry Christmas!
jjh221
May 17, 2017 05:35 AM
Toran
Mar 19, 2016 07:39 AM
AdrenalinPlease
Jan 19, 2013 06:12 AM
Alex J
Tires
Jan 3, 2011 10:12 AM
97nwdisco
May 12, 2007 05:33 PM
