Rear Climate on Start up
Old 06-23-2021, 02:25 PM
jdarwin33's Avatar
Default Mine does this every time
I have a 2020 Range Rover SVR and each time I start my car the rear climate turns on full blast. Then I have to manually turn it off on the touch screen up front. I’ve tried pushing the lock button to see if it will lock it off that does not help. It is very frustrating for me. I love the vehicle otherwise, but this is very annoying daily to deal with
Old 06-29-2021, 11:19 AM
David Hirshberg's Avatar
With the car running, manually put your rear AC above 59 degrees on the thermostat and put the fan on a lower setting. Then when you start the car again keep your forward thermostat setting above 59 degrees. If you start the car and your thermostat says Lo, then it overrides the settings on the rear AC and the rear AC starts at full blast to cool the car down quicker. If your FWD thermostat is set above Lo, then the Rear will start where you left it last. Hope that helps
knightmetro
07-19-2018 09:27 AM
thorgal
06-08-2018 08:21 PM
squealpigs
09-02-2014 09:06 AM
jsyonker
11-01-2007 07:22 PM
tads
07-16-2007 12:38 PM
Quick Reply: Rear Climate on Start up
