Roof Rails - Omfg NEED a legit answer please.
Old Oct 30, 2018 | 05:23 PM
the_wolperting's Avatar
Default Roof Rails - Omfg NEED a legit answer please.
Okay so I'm about to pull the trigger on a Disco V but it DOES NOT come with factory installed roof rails. I am being told by the dealer that it is NOT possible to have them installed aftermarket. However, Land Rover sells the roof rails separately as an accessory, which makes no sense to me if they can't be installed after you buy the vehicle. Also, I called a LR service department who told me that they CAN be installed (even though I would just have my husband do it).
I do NOT want to buy the car if I can't install the roof rails down the line. Does anyone have a definitive answer for me? I am BEGGING YOU GUYS.
My secondary question is, is it worth stepping up to an HSE over an SE? Like really? I'm so on the fence and need some guidance.
Old Oct 30, 2018 | 05:41 PM
SoCalWiley's Avatar
They can be installed after market, somebody posted the Land Rover installation instructions in one of the threads. I was going to have my dealer install them and then changed my mind, but they install them regularly.
Old Oct 30, 2018 | 05:53 PM
andries's Avatar
Someone already did it and pointed to the factory instructions (as mentioned above).
LAND ROVER ACCESSORY FITTING INSTRUCTIONS
As to HSE vs SE, what features do you want/need? What model year 2017/18/19?
Old Oct 30, 2018 | 06:42 PM
ponderosajack's Avatar
to make yourself feel better take a look at one without the rails installed - you should see removable plastic covers that are removed to install the rails
yes, they are installable
Old Oct 31, 2018 | 04:03 AM
abran's Avatar
I installed the aftermarket eBay copies.
pretty decent except the bolt hole covers are held on with adhesive tape and fell off the first wash.
Old Nov 1, 2018 | 09:36 AM
bvdave's Avatar
I had my dealer add the roof rails to my D5. Easy to do; it was just pricey. Parts & Labor was about $1,100. So keep that in mind. I had the dealer install because I’m not terribly successful when I monkey around with stuff.
Old Nov 1, 2018 | 03:14 PM
Groucho123's Avatar
If you like even one of the features in an HSE(and there are many)...just get it. I have found that it just isn't worth worrying about a few bucks for something you wanted and can't get after...
Old Nov 3, 2018 | 07:58 PM
natelw's Avatar
Here was my project this Saturday after reading this thread and looking at the instructions, but I did have to separately order the filler pieces after I got the roof rails. You MUST have the filler pieces.
Old Nov 3, 2018 | 08:32 PM
natelw's Avatar
Here is the video installation:
Old Nov 3, 2018 | 09:35 PM
Good information all, to bad the original poster never came back for any of the OMFG info.
austinlandroverbill
Jul 29, 2016 07:35 AM
Womble
Jul 30, 2015 01:58 AM
Kwakazaki
LR4
Aug 1, 2013 08:50 PM
BillO
LR2
Apr 28, 2012 04:00 PM
dvs_dale
Feb 16, 2010 06:50 AM
