side door 3rd row seat controls
Old Aug 16, 2021 | 10:06 AM
gcap's Avatar
Default side door 3rd row seat controls
Does anyone know if the seat control panel located at the second row door can simply be popped out?I’ve tried them a few times since getting the truck and they never worked but just figured I was doing something wrong, (maybe I needed to have the ignition on or the truck running) but this time I walked to the passenger side, it worked and only then did I realize the buttons on the driver’s side seemed depressed further already.
when trying to pull a button towards me its a bit loose, the other button also comes forward a bit which leads me to think the dual-button mechanism isn't attached to the surrounding panel. If it's held on by friction or a small clip, I'd try to pry it out and see if I can re-seat the switches. It just seems like a waste of time to bring it to the dealer if it's just this.
thanks,
Old Aug 20, 2021 | 07:21 AM
gcap's Avatar
would anyone have a service manual showing how this part is to be removed?
Old Aug 20, 2021 | 09:25 AM
bkjecu94's Avatar
You should just be able to use a trim removal tool... Sometimes they are tough to pop out depending on what is holding them. I do not believe there are any screws holding that part.
Old Aug 21, 2021 | 09:12 AM
gcap's Avatar
That was also my thinking as well, I actually remove some on a regular basis when cleaning a work truck. My issue is that on one occasion in the past, I broke off 2 retaining hooks that were molded to the plastic panel as I removed it from the wrong direction. I was curious if this may be the case which is why a picture or diagram of the part would help.
p400_au
Jul 21, 2021 08:22 PM
MichiganRover
LR4
Feb 9, 2020 07:09 PM
disco5fl
Aug 9, 2018 10:14 AM
aguison
Dec 17, 2014 01:41 PM
ChanchoVerde
Nov 25, 2009 11:08 PM
