TD6 Timing Belt Replacement cost
Old Mar 23, 2025 | 02:33 PM
RyanLR3's Avatar
Completed the front timing belt yesterday and it was pretty easy. Biggest hassle was the coolant on the garage floor. Did all the timing pullies as well as the accessory belt idlers and tensioner. I skipped the water pump the bearing felt great, I did do the t-stat just cuz. I bought a Chinese belt tool kit, which was a little sketch, but it worked. Tons of room to work in the engine compartment was a treat.
Old Mar 24, 2025 | 05:17 AM
gmfain's Avatar
How hard was it to lock the fly wheel?
Old Mar 24, 2025 | 07:07 PM
RyanLR3's Avatar
It was easy. The Chinese tool Didn't fit into the flexplate as snug as it should but it worked good enough. I was pleased how easy the starter is to remove
Old Mar 25, 2025 | 04:49 AM
gmfain's Avatar
That's good to know. I'm on the fence about changing it. My indy shop will do the job for a grand, parts and labor.
Old Mar 25, 2025 | 10:13 AM
ar077's Avatar
My 2017 Td6 will be 8 years old in June but it has less than 64000 miles on the clock. Is timing belt wear time-sensitive or mileage-sensitive?
Old Mar 25, 2025 | 02:09 PM
gmfain's Avatar
I'm not sure about our TD6 engine on time. But my VW is 130K miles or 10 yrs, which ever come first.
I will ask my indy shop next time I talk to them.
Old Mar 25, 2025 | 02:16 PM
RyanLR3's Avatar
I believe it's 112k miles or 7 years.
Old Mar 31, 2025 | 01:31 PM
soarvet's Avatar
where do you take yours?
Old Mar 31, 2025 | 01:33 PM
soarvet's Avatar
Where do you take yours?
Old May 16, 2025 | 11:45 AM
sowrco's Avatar
I managed to find the Ford F150 instructions for this but not the Land Rover instructions - does anyone have access to these? Thanks!
