TD6 Timing Belt Replacement cost
Old May 16, 2025 | 11:54 AM
  #21
ar077's Avatar
Originally Posted by sowrco
I managed to find the Ford F150 instructions for this but not the Land Rover instructions - does anyone have access to these? Thanks!
PDF attached.
File Type: pdf
Old May 16, 2025 | 02:00 PM
  #22
sowrco's Avatar
Thank you.
Old May 16, 2025 | 02:16 PM
  #23
ar077's Avatar
Thank you.
My pleasure! If you do the job please post how it went and if there were any gotchas to be avoided.
Old May 17, 2025 | 11:35 AM
  #24
sowrco's Avatar
I can do that.
Old Jan 12, 2026 | 04:30 PM
  #25
LR disco 5's Avatar
Does anyone change the oil pump while doing this service I have seen on other forums with the td6 they replace it but is it worth it to do it. Also what should be changed when getting this job done.
Old Jan 12, 2026 | 05:47 PM
  #26
sowrco's Avatar
Sorry about the late reply. The job has been completed. My son did the work, he's a certified mechanic. I bought the kit for about $200, it included the belt, 2 pulleys, the tensioners and a new bolt. The job took him 2.5 hours, he said it was one of the easier timing belt jobs he had done due to the amount of space to work - he did not lock the crank, he used a timing mark on the crank pulley and relied upon a good fit for the pins. Water pump felt fine, no obvious leaks anywhere. (2018, 95K miles).
Td6 new timing belt.
Old Jan 13, 2026 | 04:47 AM
  #27
gmfain's Avatar
My mechanic said it wasn't necessary to change the oil pump at the 112K mile mark.
I've followed his advice for 25 years.
Old Feb 10, 2026 | 07:37 AM
  #28
DrMurm's Avatar
Default Mechanics in Birmingham AL
2017 LR Disco HSE Luxury TD6
So I got a quote from LR for $5k+ for front only. My regular independent shop doesn’t do timing belts. Help!
Old Feb 10, 2026 | 09:19 AM
  #29
lndrvr90's Avatar
May consider giving Bear Valley over in Atlanta a call
Old Feb 10, 2026 | 12:38 PM
  #30
sowrco's Avatar
Try Cody Phillips at CP's Garage.
@CPsGarage
