Thinking of replacing wheels
Old Mar 17, 2022 | 08:07 PM
  #21
ammonation's Avatar
Originally Posted by BritCars
Any tire shop that you trust. Easy job. Would use one with a road force balancing machine to get the balancing as true as possible
Personally avoid the cheap chains as I've had overtightened lug nuts and some scuffing of the alloy wheel.
Yea that is the problem, don't have a shop I trust. Haven't hard a car in for service outside of a cheap chain in over 10 years.
Old Mar 22, 2022 | 01:25 PM
  #22
mxstyles's Avatar
5th Gear
hi all, I too am in NJ and would like to even go smaller on my wheels. Currently have the 20 inch on my D5, but would like to go down to a 19 or 18 inch and add some nice sidewall for our lovely NJ pot hole filled roads. Thinking of the toyo open country which I have on my L322 and love.
Old Sep 29, 2022 | 02:42 PM
  #23
Vin's Avatar
Vin
Originally Posted by ammonation
What type of shop would I take my brand new Rover to get the wheels swapped?
I took my brand new Rover to Discount Tires to swap the OEM’S. They were familiar with the process of raising the air suspension, which certainly engendered my trust.
Old Oct 18, 2022 | 08:09 PM
  #24
Honeybadger1976's Avatar
Default DISCO 5 Wheel Change with 2021 Defender 20 inch wheels
Het guys,
I just joined the LAND ROVER Forum. I could use some advice. I own a 2017 DISCO 5 HSE with the Stock 21 inch wheel set up with 275/45/21 wheels are 9.5jx21 ET49. I found a good deal on a set of 5 OEM 20 inch wheels from a 2021 LAND ROVER DEFENDER. From my research I see that the LAND ROVER DEFENDER Wheel set up are 255/60/20 and the wheels are 8.5jx20 ET 41.5. Will the DEFENDER wheels fit my Disco 5?
Appreciate any help!
Thanks
Old Oct 26, 2022 | 07:07 AM
  #25
Rover06's Avatar
Purchased 21's" off eBay yesterday, for $2000. Comes with 4 Pirelli Scorpion tires with only 80 miles on it, which is clutch wasn't a fan of picking up used tires. Will have to buy a 5th to use as a spare since our spare is a 22".
I just picked up the exact same set to replace my stock 20's. Car is going in for service on 11/9 so I may have them do the swap and pull the TPMS sensors out of the current wheels. Just need to decide if I keep the old ones wrapped in the used Goodyears or just have them toss the tires so i can sell the wheels alone..
Old Oct 26, 2022 | 09:16 PM
  #26
ponderosajack's Avatar
Usually you want to lower the air suspension before lifting the vehicle. This reduces pressure in the bladders. So if you Discount tire raised the air suspension they did it wrong.
Old Oct 27, 2022 | 06:59 PM
  #27
BritCars's Avatar
Are you sure? I'm pretty sure LR says to raise it. That's what I've always done. As the wheel articulates a very long way when you jack it up, so raising the air suspension first reduces the remaining travel and therefore the amount by which you have to jack it to get the wheel off the floor
Old Oct 28, 2022 | 10:10 PM
  #28
My Discount Tire for years has told me to lock it in Access Mode before they lift it. Same for my LR3 since 2006.
But on the online Owner's Manual for my D5:
WARNINGFor vehicles fitted with an electronic air suspension, select off-road height before jacking the vehicle. See OFF-ROAD HEIGHT.
Wow, it's my Discount Tire stores that are ill informed. That said, I've been doing it in access mode for 16 years and never had an issue.
Masbury
Oct 31, 2021 11:28 AM
wcc18999
Oct 15, 2021 12:34 PM
BigBoss0311
Jan 19, 2012 09:56 PM
saga
Jan 6, 2008 11:49 AM
qwertmonkey
Aug 10, 2007 10:16 AM
