Towing instructions in Operation Manual
Old Jan 14, 2021 | 03:29 AM
gmfain's Avatar
The procedure can also be used for changing from low range to high range with the vehicle traveling at a speed of less than 37 mph (60 km/h).
So yesterday.... from a a stop, I put into low range.......... started driving.....when I reached 35mph I put it in Neutral, pressed High range button......after it lit up, I switched back to Drive........ worked flawlessly.
Hope this helps
Old Jan 14, 2021 | 04:28 AM
Hokewe's Avatar
Hi gmfain,
thanks for testing that. Must feel a little strange during shifting, rolling along in N until changeover is done. I assume you tried solo, i.e. without a trailer?
But again, is it needed every time when towing a trailer? I might be tempted to do so when driving off uphill on a steep mountain pass or somewhere offroad, but on a normal highway or in town? What do you think?
As a second thought it must also be possible without, as what would you do with a Disco without a transfer case...AFAIK they also have the same towing capacity.
Cheers
Hokewe
Old Jan 14, 2021 | 04:48 AM
gmfain's Avatar
I don't think it is necessary. If you have a extremely heavy load, just use common sense and take of slow and easy, until you reach desired speed.
rbelz
Dec 13, 2008 11:34 AM
snugg
Jul 7, 2008 08:23 PM
Mark G
Oct 7, 2007 09:29 PM
lionmonkey
Defender
Jul 25, 2007 06:25 PM
Uberwagon
May 21, 2006 12:09 PM
