Toyo AT3 275/55/20
Old Jun 25, 2021 | 03:25 PM
nwr1967's Avatar
Default Toyo AT3 275/55/20
Anyone have success running these with no lift or modifications? I will be using a 20x8.5 RRS wheel. Have searched the forums and have only seen ppl running the 255. Thx.
Old Jun 26, 2021 | 06:24 AM
n559br's Avatar
They're only 3/4 inch wider and a little over 3/4 taller. It will throw your speedo off by about 2mph at 60. But I don't think handling would be too bad. If you went with a 275-50 the speedo error nearly goes away and leave you basically at stick height. I've got the 255 Toyos and agree I would like to have a wider tire.
Old Jun 26, 2021 | 11:30 AM
nwr1967's Avatar
Thanks. Not too concerned about the speedo or height. Just if they fit without rubbing.
Old Jun 26, 2021 | 01:49 PM
n559br's Avatar
I doubt 3/8 inch on each side would rub. If you went out to 315s you would probably have issues. My tires are already way in from the fender wells. I know some folks are running spacers wider than that and are not rubbing.
vulturez
May 5, 2025 11:54 PM
DefendThis
Nov 24, 2020 10:43 PM
DiscoBear159
May 18, 2018 01:38 PM
shady milkman
Apr 26, 2017 08:59 PM
knightmetro
Apr 15, 2015 07:46 AM
