Transmission Service
Old Oct 20, 2022 | 10:14 AM
RyanLR3's Avatar
Originally Posted by gmfain
Bingo! Thanks so much.
Old Oct 20, 2022 | 01:30 PM
sowrco's Avatar
When the time comes I'll probably use this:
https://www.blauparts.com/land-rover...7-20-8spd.html
Old Oct 20, 2022 | 08:17 PM
ponderosajack's Avatar
That's a pretty good kit. ZF transmission on my BMW calls for a kit like that with a new pan including filter, new bolts, gasket and fluid.
My Discovery service manual just called for a drain and fill.
Not sure if that new pan and filter is needed, can't hurt.
But if we are changing the lifetime fluid at 60K miles, maybe we could skip the new pan and filter and replace it every other time at 120K miles.
Note that my service manual called for 8.5 Liters and that kit comes with 7 Liters. Maybe it all doesn't drain out but you might need to have a couple extra liters on hand just in case.
Per the kit supplier: My 8.5 Liter spec is for a dry fill - 7 Liters adequate for a drain and fill.
Old Oct 21, 2022 | 06:24 PM
LR disco 5's Avatar
if somebody is doing this great to know what tools because Ive seen videos where they recommend using a autel scan tool and stuff so if somebody would do it and document would be amazing planning on doing at 100k kilometers and am at 70k now
Old Oct 21, 2022 | 06:35 PM
RyanLR3's Avatar
I use the torque pro app on my Android and Bluetooth DLA. Have you create custom trans Temp gauge with LR PID. The PID and process is online in LR forums.
Old Oct 23, 2022 | 01:16 PM
Hokewe's Avatar
Hi RyanLR3,
can you please be a bit more specific, as I do not get your remark. Similar to what LR disco 5 wrote, I am looking for what to use on my Disco 5 to check on TM temperature while towing.
Thanks
Old Oct 23, 2022 | 02:57 PM
RyanLR3's Avatar
Originally Posted by Hokewe
Hi RyanLR3,
Thanks
Download Torque Pro App. I got mine from Google play store.
you'll need one of these or similar
Amazon Amazon
Instructions below as to how to get and import Land Rover specific CAN messages. Do not use the transmission temp that comes with the torque app, it's not accurate. It displays the engine coolant temp.
https://www.google.com/url?sa=t&sour...4nvacWz_73FgWA
Old Oct 24, 2022 | 01:37 PM
Hokewe's Avatar
Thanks
gfly66
Mar 22, 2017 10:13 PM
Roverrrgirl
Dec 8, 2016 04:51 PM
djkronik57
Nov 9, 2016 11:26 AM
notsleepy
Feb 10, 2014 03:46 PM
