USB Ports not working & CarPlay
Old Nov 3, 2019 | 10:13 AM
cocca's Avatar
Default USB Ports not working & CarPlay
The USB ports under the center arm rest don't work. Any clues, hints, tips or suggestions?
This forces CarPlay to perform worse than normal.
Old Nov 3, 2019 | 02:14 PM
BchBum11511's Avatar
I had that problem when I was on the older infotainment SW. Since upgrading to the latest, I haven't had an issue with those ports.
Old Nov 3, 2019 | 03:03 PM
cocca's Avatar
How do I update?
Old Nov 3, 2019 | 04:28 PM
If you have 19A (maybe 18D), you can check for an update under SW Update in the Settings menu (its the new over the air update).
If you are on a prior version of SW, you’ll have to take it to the dealer. You can see your version in that same place.
Old Nov 4, 2019 | 04:28 PM
BalanBro's Avatar
I was on 18D. Had to take mine to the dealer for a software update, which basically just enabled over the air updates. I was then able to search and find the update. Took a few days to download and install; now I'm on 19B.
DSW
Range Rover L322 (3rd Gen)
Jan 3, 2019 09:49 PM
DakotaTravler
Dec 26, 2017 03:35 PM
PC-06-LR3
May 13, 2017 08:18 AM
408 Limey
Sep 25, 2012 04:47 PM
elitepro
Audio/Visual Electronics
Mar 13, 2009 06:48 AM
