Wiper Challenge
Old Jan 16, 2020 | 07:14 PM
ToiletDuck's Avatar
Originally Posted by dbuseman
I suppose but if they're on automatic and you start the vehicle before checking you would think there would be a relay that senses resistance and stops. Much older other cars have never done that. I thought maybe land rover made it get loose on purpose and there was a simple reset to get it on line. Thanks!
ah that’s different. I live in Texas and don’t know what Ice is so I apologize I thought you saw a pile of ice/snow and forced it on. Definitely go by the dealer. While there make sure you get everything updated software wise. It will be a free upgrade!
Old Jan 16, 2020 | 07:22 PM
ponderosajack's Avatar
Haven’t looked at my Disco but every other car I’ve had has a bolt or nut on a stud under a removable or flip open cover where the wiper arm attaches to the shaft that rotates the arm. Usually but not always this attachment point is splined but some are not and if that’s the way the D5 is made you should be able to just tighten the nut or bolt. But don’t strip it or damage the drive motor and make certain the arm is in the correct parked position before tightening. Maybe yours was loose and maybe your other one is too loose too.
Old Jan 16, 2020 | 10:23 PM
andries's Avatar
You can set the wipers to the winter park position. This allows you to lift it from the windshield, it also seem less likely to freeze in that position as it is more angled.
Dv8er
Feb 26, 2017 09:11 PM
LuisGT3
Oct 12, 2016 03:46 PM
LR2driver
LR2
Oct 21, 2014 04:52 PM
Navy_Jak
Jan 5, 2010 11:07 PM
stupid
Dec 20, 2008 05:18 PM
