Old Sep 19, 2021 | 05:35 PM
Buddy101's Avatar
7th Gear
Default 2
The 2004 Land Rover Discovery I own was sold to me by an dishonest person. Within weeks the car started to overheat, blow steam/smoke out of the engine, leak multiple fluids, and not run well. How much do you think it would be to fix all these problems?
The back of the car has lowered significantly? Any causes? There are these blue suspension bags that appear to be deflated??
Old Sep 19, 2021 | 06:03 PM
With the info given it's impossible to answer your how much question. The rear appears to have Air Suspension that has deflated. When the vehicle is running the air compressor will kick on and reinflate the system. It is not uncommon for them to sink when sitting for a time. Obviously with your description above I wouldn't recommend idling the truck to see if it comes up.
What's your coolant level look like and what fluids are leaking?
Old Sep 19, 2021 | 06:20 PM
Buddy101's Avatar
7th Gear
My coolant disappears. The owner told me to top up with water when it goes down... The coolant hose not good either. Oil and a reddish liquid also leak
Old Sep 19, 2021 | 07:10 PM
stillruns's Avatar
Stick a fork in it. You'll spend more $$ than you want on it and than it is worth, way more. Sell it and get a Honda or Toyota. Sorry. Hope you didn't pay much. How many miles??
Fyi, It is a 2004 Land Rover Discovery Series II, not a Series I.
Old Sep 21, 2021 | 06:04 PM
disco96sd's Avatar
Is it insured ? Shhhhhh - it was stolen or it caught fire
Old Sep 21, 2021 | 07:09 PM
So you knew it was loosing coolant, is it all coming out leaking or blown hoses?
Redish is either trans, power steering or ACE
Old Sep 25, 2021 | 08:57 AM
Buddy101's Avatar
7th Gear
Huh????? It had insurance but I stopped paying it because it won’t run… I don’t know what you mean by your comment. It was not helpful at all. But, thank you for the reply.
Old Sep 25, 2021 | 08:58 AM
Buddy101's Avatar
7th Gear
There is at least one blown hose. The one leading to the coolant. It leaks several pieces under the vehicle as well. I believe it is leaking oil
Old Sep 25, 2021 | 09:00 AM
Buddy101's Avatar
7th Gear
I paid a good price. Basically the prove of this car without an engine lol. Thank you for the correction. It has around 180,000 miles.
Old Sep 25, 2021 | 02:12 PM
Harvlr's Avatar
If you got it for the price of the car without an engine I don’t think the seller was dishonest. He told you about the coolant leak. If you want to keep your Disco it sounds like it needs a lot of work. As said above maybe you should sell it, again for the price of the car without an engine.
