If you got it for the price of the car without an engine I don’t think the seller was dishonest. He told you about the coolant leak. If you want to keep your Disco it sounds like it needs a lot of work. As said above maybe you should sell it, again for the price of the car without an engine.
To answer your question, The cost to fix these issues will depend on how much of this work you do yourself.
Clearly you need a head gasket and some cooling system parts...
The red fluid could also be your antifreeze, I'd guess the PO had Dexcool in it.
Using a shop the above work would be $2000 - $2500
That's just the starting place... But you got nothing until this is done first... Once you are not overheating you can deal with all the other issues or read all about them here and learn on your own vehicle... Which is a great way to go btw.
Good Luck!
Good Luck!
Out of curiosity l have to ask...where are you located? The frost on the roof, christmas lights in the background, no leaves on the trees...has got me confused about the time frame of this picture.
The owner told me to top up with water when it goes down... The coolant hose not good either. Oil and a reddish liquid also leak
Showbox jiofi.local.html tplinklogin
Harear
Aug 23, 2021 09:54 PM
