disco2 oil pump
Old Apr 27, 2020 | 07:23 PM
231john's Avatar
5th Gear
Default disco2 oil pump
I'm replacing the oil pump. my question has to do with the center gear ( with the keyways, that rides on the crank shaft). if you slide it back it sits flush with the center sprocket but sliding it forward it sticks out a bit, not flush. when assembling this piece does the flush end face the rubber seal ( towards radiator) or does it face the oil pump cover plate ( towards engine block)?
this pic shows the center sprocket slid forward to the not flush position
Old Apr 27, 2020 | 08:29 PM
KernowDiscovery's Avatar
You may want to post this up in the DII section of the forum and also your truck's birth date.... Not sure if all DIIs are created equal.
Som
Jun 25, 2014 12:02 PM
bladeski
Jan 24, 2014 02:19 PM
Q8_Discovery
Oct 24, 2012 05:33 AM
andrew65
Off Topic
Jan 28, 2009 09:50 AM
NateLR2
Nov 10, 2008 07:17 AM
