Engine swap
PART 1 (10 days ago)
Okay... so I'm about to replace my engine in my 04 discovery.
Very excited as it's ran like **** for the past 8 mths.
I've got a well recommended mechanic that's also an enthusiast and specializes in rovers.
I've never ever had an engine replaced. I'm a bit apprehensive with spending this kind of money on a used engine.
Please share some advise, knowledge and wisdom.
The engine is said to have 90K miles? its coming from another rover he have bought (as I was close to selling mine for good usable parts).
His word is: Before replacing engine with the his great running engine... he will rebuild the top half before installing it he said a lot of mechanical jargon (new heads, new valve stem, cover, gaskets, plugs, wires, etc... $3300)
Sounds good.
Please share wisdom and experience. I'm a bit nervous as I mentally can't tolerate another mechanic "F' over" in my life.
I'm not real trusting but I need this done, so I can enjoys loving my truck again.
Any advise is needed and appreciated
Part 2 (today)
I picked up my truck today... I sounded great. Everything was done as promised.
Sounded perfect. Drove as well as you could want your rover to drive.
drove it 40 miles on interstate. pulled it over to get gas, drove around the corner to emissions, noticed oil pump light came on. car started funny (as in when a car is low on oil). I called mechanic immediately and told him the story.
He will be sending a wrecker out to retrieve vehicle. He told me I shouldn't have drove it with the oil lamp on. I told him not even start that "my fault" ****, I'm not a mechanic but I know better... He said he will fix whatever the problem is he said he'd swap out oil pump if thats the case.
He seems honest. I'm very untrusting and a bit shiity at the situation.
Although this happened. The vehicle drove excellent. But now it have indicator light on and it's ticking.
Any advise please
Sounds good.
Part 2 (today)
Any advise please
Sorry to hear that you're having such difficulties. Just a head's up - you may receive a better response if you post it in the forum for Series II Discoveries or General Tech Help. Currently it is posted in the New Member Introduction. Best of luck.
