New Disco II Owner
Old Jul 29, 2013 | 02:47 PM
knifeknut's Avatar
6th Gear
Default New Disco II Owner
Just bought a 2003 Disco II SE with 88,000 miles. Upon first inspection I noticed the torque converter (bell housing) inspection port cover was missing. Used a Kerr canning lid and 3 stainless bolts to fix it. Not Land Rover approved, but worked!
Old Jul 29, 2013 | 05:54 PM
Good deal. While under there check for grease fittings on the double end of the front drive shaft. If none, it would be an oem one, subject to snap without warning and beats hole in transmission. Rebuild article in our tech area.
Also - that temp gauge can't be trusted, any thing above 50% is overheating. It will point at 50% from about 130 - 240 F.
Shop manual set is called the RAVE, free download links below.
And welcome!
Old Jul 30, 2013 | 12:53 PM
knifeknut's Avatar
6th Gear
Is the problem with the gauge or with the sensor? I have a scangauge hooked up and was using that as a back up. Is that adequate, or should i try to add an external gauge?
Old Jul 30, 2013 | 04:23 PM
Scangauge is fine. See https://landroverforums.com/forum/ge...ter-6-a-51033/
Old Jul 30, 2013 | 06:20 PM
dgi 07's Avatar
Very nice fix!
Old Jul 31, 2013 | 08:27 AM
knifeknut's Avatar
6th Gear
Thanks!
Run33
May 11, 2015 09:43 PM
kayak74
Jan 23, 2013 07:13 AM
jswift
Jun 21, 2011 12:12 PM
MuddMouth
Sep 30, 2010 10:30 PM
desh72
May 5, 2007 12:03 AM
