I wonder what this would run like
Just for conversation. Say you didn't have a strict budget, I wonder what it would be like if you swapped this in place of the factory induction...
Then installed this
Finally toss in a high quality MSD distributor/ignition. I wonder if it would run better? Worse? Same?
The stand alone system would practically bolt it. It needs a coolant temp sensor and an o2. Which we all have. We could even use the same fuel system. I wonder if the added simplicity would be worth it. EFI kit is stupid expensive. My truck actually isn't all that hard to work on. But just curious.
Then installed this
IMO I'd stick with EFI but that's just me. The manifold looks like the type to accept a Holley multichoke carb. I've used twin horizontal Webber carbs many times years ago and what a pig they were to fire up from cold. I'd even use soft plugs to start and run for 5 minutes then switch to harder plugs. Never again!
Freedom38
02-15-2015 06:47 PM
wisconsinoverlander
04-26-2012 10:24 AM
Frank4
06-03-2010 09:12 PM
2k2wranglerx
06-19-2006 05:18 AM
