I wonder what this would run like
Old Apr 4, 2015 | 08:36 AM
Shiftonthefly1's Avatar
Default I wonder what this would run like
Just for conversation. Say you didn't have a strict budget, I wonder what it would be like if you swapped this in place of the factory induction...
Then installed this
Finally toss in a high quality MSD distributor/ignition. I wonder if it would run better? Worse? Same?
The stand alone system would practically bolt it. It needs a coolant temp sensor and an o2. Which we all have. We could even use the same fuel system. I wonder if the added simplicity would be worth it. EFI kit is stupid expensive. My truck actually isn't all that hard to work on. But just curious.
Old Apr 4, 2015 | 08:41 AM
Atomic EFI TB Installation Video:
Old Apr 4, 2015 | 10:16 AM
drowssap's Avatar
why even run the efi, put a carb on. With a 1-wire alt, and 1-wire GM distrutor. Every ecu in the truck could burn up and it would still run.
Old Apr 4, 2015 | 10:31 AM
True. But the efficiency and cold start abilities of EFI keep me away from carbs. Plus I've always had issue w the float bowls at extreme angles. Stalling on a steep incline is no fun.
Old Apr 4, 2015 | 11:20 AM
You could probably cut the injection costs down by using a old gm tbi setup. There are a few companies out there that do them and will custom map it for your engine
Old Apr 4, 2015 | 04:54 PM
OffroadFrance's Avatar
IMO I'd stick with EFI but that's just me. The manifold looks like the type to accept a Holley multichoke carb. I've used twin horizontal Webber carbs many times years ago and what a pig they were to fire up from cold. I'd even use soft plugs to start and run for 5 minutes then switch to harder plugs. Never again!
m3dragon
Feb 24, 2015 10:08 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
2k2wranglerx
Jun 19, 2006 05:18 AM
