LR2 discover* TC, HDC,& ABS LIGHTS CAME ON
Old Jan 2, 2008 | 06:29 PM
tetio2000's Avatar
Default LR2 discover* TC, HDC,& ABS LIGHTS CAME ON
Hi everyone I am new to this excellent forum and I hopping to get some help or some advice from any of you LR2 owner my is a 02 discover*II West Minister
one day this three lights came on. I new I needed brakes pads so I went ahead and took it to the mechanic to fix the breaks
TC , HDC failure and ABS lights would not go away, please somebody HELP!!!
thanks
Old Jan 2, 2008 | 08:34 PM
05LandRover's Avatar
Default RE: LR2 discover* TC, HDC,& ABS LIGHTS CAME ON
I'm sure there is a reset switch somewhere for those lights as all three of those systems use the brakes.
Did you take it to a Land Rover center or just any mechanic? It's probably like a check engine light and needs a special tool to be turned off. I don't have a Disco II... yet.
Old Jan 3, 2008 | 09:57 AM
tetio2000's Avatar
No I did not take it to the land ROver Dealer yet, they want to charge 150.00 just to run the diagnostic, and Iam trying to avoided if I can, but if I have no other options, I will have to do that. thanks you for the advice.
Old Jan 3, 2008 | 05:13 PM
DiscoOn22s's Avatar
tetio next time go to the general tech threads. the three amigos as most rover owners refer to them can only be cleared by the dealer. they are a well documented problem that all disco owners go through at some point. find disco mike he can tell you more about it or just search the site for them you'll find many threads about them. PS my dealer wants 179.00 to diagnose mine. lol where do you live??
Old Jan 3, 2008 | 05:48 PM
tetio2000's Avatar
Hi DiscoON22s
thanks for your advice I will do that
I live in los Angeles CALIFORNIA by the LAX AIRPORT and here is a landRover authorize independent repair shop call British Car Service (310) 216-3400 and they charge 125.00 to run the Diagnostic
Old Jan 4, 2008 | 07:26 AM
This is not a question answer spot on this sit. Place you questions in the right place, Thanks.
Alan Phillips
Nov 19, 2018 03:27 PM
ugottatri
Apr 17, 2015 05:55 AM
tetio2000
ROAMING WITH FRIENDS
Jan 5, 2008 12:47 PM
tetio2000
Jan 4, 2008 11:34 AM
cottonpatchweims
Jan 14, 2005 01:59 AM
