TD5 Disco 2 65MPH Flat Out!!!
Old Jan 14, 2005 | 05:44 PM
Dave2345805's Avatar
Default TD5 Disco 2 65MPH Flat Out!!!
My vehicle has been to two dealerships and they have been unable to trace any fault with their code readers on the brain/ECU. As you can see from the subject my Disco will only do 65 MPH flat out and doesn't rev up or accelerate very quickly. I have had fitted a Mass Air Flow sensor and Manifold Absolute Pressure sensor, it has had a brand new turbo fitted and the exhaust is not blocked, having all this changed has made no impact to the performance of my Disco and will still only do 65 MPH flat out!!!
Has anybody had this problem or have any suggestions as to what may be at fault??
Also the ECU has no faults on it at all and all readings are correct.
HELP ME PLEASE!
Old Jan 21, 2005 | 04:36 AM
Lighting90's Avatar
Default RE: TD5 Disco 2 65MPH Flat Out!!!
erh, does not sound good to me.. my J reg 90 with the lower gearing will do 90mph.. with the old 200TDI....
Have you tried reving the engine from under the bonnet, as it uses a thingy, (not sure what they call it) that changes the pedal movement to a electric signal. It is normally located not far from the pedal boxes in the engine bay.
If still under warrenty, I would get the dealer to do a swap of the ECU... as a test.
Old Jan 26, 2005 | 02:41 AM
Bene's Avatar
im pretty sure thats the throttle
Old Jan 26, 2005 | 03:58 AM
Lighting90's Avatar
I would have thought they would give it some fancy name, so the garages can baffle the end users when they are doing a regular service.. "well sir, we had to replace your... " " and that will be $200 plus labour"
Old Feb 22, 2005 | 04:16 PM
We have now been able to cure the Disco of its faults it was down to the injectors, they are two stage injectors, the first stage of the injectors was normal but the second stage (which is mechanical worked by a cam system) was not reaching 15,000psi (as stated in Land Rovers manual), therefore not enough diesel was being put into the piston chamber, so half the diesel means half the power.
Thanks to anyone who has replied to this message your efforts are greatly appricated.
Old Feb 23, 2005 | 02:10 AM
Bene's Avatar
also known as "running lean"
Old Feb 23, 2005 | 04:01 AM
Lighting90's Avatar
good to know what the problem was..
Old Aug 2, 2015 | 09:09 PM
Frenchy's Avatar
fuel saving mode
pgaukroger
Feb 29, 2016 05:56 AM
Tom ferrier
May 20, 2013 08:51 AM
jfall
Jul 3, 2012 08:38 AM
northernlilywhite
Nov 11, 2011 09:54 PM
camomile
Freelander
Dec 6, 2010 09:14 PM
