P38 rangerover crank shaft senser not working
Old 12-07-2010, 08:29 PM
Landlover12's Avatar
4th Gear
Default P38 rangerover crank shaft senser not working
Can I just replace this or is there a procedure that I have to go through? The OBDII tester said that the unit is broken but the vehicle seems to run great, should i replace this??
Old 12-08-2010, 06:12 AM
Rovin4life's Avatar
what is the code you are getting?
Old 12-09-2010, 09:17 AM
4th Gear
Default P38 crank shaft sensor....code
This doesn’t make too much sense to me, I ran my codes and canceled them to see if the engine check light would come back on after I drove around for a day or so, but it did not???? I am still going to replace the part because I know that they go bad after a certain amount of miles. I do all the work on my own and I was wondering there is any difference with installing this sensor compared to putting an oxygen sense in? Also i am taking the car on a 10hr drive next week and i dont know if i will get te part in time is it bad to drive with a bad one??
The code is p0335
the other codes that came up are=
p1314
p0158
p1193
Old 12-09-2010, 11:10 PM
handsome rob's Avatar
What year is the rover? If the sensor is bad then it will either not start or it will stall out after a few minutes. I have not much issue with them on the GEMS motor but on the Bosch they fail all the time. I would at least buy one and keep it if it is Bosch just in case.
Old 12-10-2010, 07:41 AM
4th Gear
The range is a 96 4.0 whare should i get it? I normally get my parts off of rovers north but I did not find the part on there site?? The check engine light still has not come back on i am not shure whats going on
96 p38 Range
1978 Toyota FJ-40 (For Sale)
Old 12-11-2010, 11:30 PM
Atlantic British has them, I do not have the part number though. They run about $85 if I remember what I paid last.
Old 12-12-2010, 07:54 AM
4th Gear
Default Thanks 938 crank
I just ordered it to be overnighted to me so that i have it when i drive south on thursday.I want to spray the bolts in advance, whare exactly id it located and also do you know of any junk yards over the internet thati could buy prts from?
Old 12-12-2010, 10:48 PM
It is on the lower drivers side of the engine toward the rear by the bell housing of the transmission. It is probably under a cover so it may not be all that obvious. If you look on you tube you should be able to find a video of it, you may need to search for a D2 video but I am willing to bet they are similar.
Most wrecking yards will ship to you, they do not get all their business locally unless they are a pick and pull.
Old 12-16-2010, 07:38 AM
interequip's Avatar
4th Gear
Old 04-02-2011, 12:27 PM
interequip's Avatar
4th Gear
4x4lover
03-16-2013 08:38 PM
Benjamin Wright
02-23-2013 10:22 PM
redw&blue
10-15-2010 10:05 AM
ERICM63
01-13-2009 12:35 PM
asat
11-03-2008 09:59 PM
Quick Reply: P38 rangerover crank shaft senser not working
