Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
1988 Range Rover no idle speed
Old Mar 14, 2023 | 04:19 AM
Dre’s Cars and Things's Avatar
Default 1988 Range Rover no idle speed
Hello guys, I have a 1988 Range Rover 3.5 and recently it was overheating, so I replaced the head gaskets, it has been a 3 month process… long story short is that I had to retard the timing so she would start and she runs about 1100 rpm’s (timing is about 12-13 degrees distribuidor is at the end of travel), but it won’t idle and stalls if put in gear. I clean the intake throughly, it seemed like an iac issue…I have installed a new iac it seemed better but still stalling. The Efi light is on on dash but it is dim… I tried moving the wires on the cap thinking I need to retard timing more but it didn’t help… compression is 140-150 psi, did a leak down in all cylinders and it is ok… I am a master mechanic by the way, but I guess not master enough for a Land Rover…any help it would be appreciated!! Thank you!!
Old Mar 14, 2023 | 09:48 AM
Harvlr's Avatar
Dre, as your engine would be common to an early Disco 1, you could post your question there as well. The D1 section gets a lot more traffic than the RRC.
jbiedlin
LR4
May 11, 2021 12:39 PM
adrian1911
Range Rover L322 (3rd Gen)
Apr 25, 2020 09:59 AM
Brock88
Oct 31, 2017 12:02 PM
ShaggySE7
Jul 19, 2016 01:50 PM
mod_junkie
Aug 23, 2010 03:58 PM
