No crank 93 RRC
Let me describe the total situation in detail.
Can not crank with key.
This is what we have and have done:
12.8 volts at battery
Only 10.3 volts at starter wire from switch in start position
Starter will work with a lead straight from battery to the spade on starter
12.8 volts at the ignition switch
10.3 volts at coil with ignition in accessory position.
No voltage drop from battery to frame.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
Your starter main power doesn’t go through the switch so my bet would be no. I would disassemble all the main power connections, positive and negative, and clean and reassemble them first.
I’m not a professional car mechanic, I’m just telling you what I’d do.
Power to the starter is fine. As as I stated in the opening post the voltage drop is at the signal wire to the solenoid from the ignition switch.
If I apply 12 volts to the solenoid signal spade it starts. There is only 10…. Volts coming from the signal wire from the ignition.
