Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
No crank 93 RRC
Old Mar 12, 2024 | 08:46 PM
DiscoMerlin's Avatar
Default No crank 93 RRC
Let me describe the total situation in detail.
Can not crank with key.
This is what we have and have done:
12.8 volts at battery
Only 10.3 volts at starter wire from switch in start position
Starter will work with a lead straight from battery to the spade on starter
12.8 volts at the ignition switch
10.3 volts at coil with ignition in accessory position.
No voltage drop from battery to frame.
Any ideas?
Thanks in advance
Old Mar 12, 2024 | 09:07 PM
Harvlr's Avatar
My first stab would be to clean all the main power wires, positive and negative. How are the engine to frame ground connections? Main positive to battery connections?
Old Mar 12, 2024 | 09:17 PM
Default Cleaned
No voltage drop on frame or at switch input.
But when in accessory position there is a voltage drop on the switch output
Old Mar 13, 2024 | 02:52 PM
Cannot trace the voltage drop. Do you think that it may be the switch itself?
Old Mar 13, 2024 | 03:02 PM
Harvlr's Avatar
Your starter main power doesn’t go through the switch so my bet would be no. I would disassemble all the main power connections, positive and negative, and clean and reassemble them first.
I’m not a professional car mechanic, I’m just telling you what I’d do.
Old Mar 13, 2024 | 03:09 PM
Power to the starter is fine. As as I stated in the opening post the voltage drop is at the signal wire to the solenoid from the ignition switch.
If I apply 12 volts to the solenoid signal spade it starts. There is only 10…. Volts coming from the signal wire from the ignition.
Old Mar 13, 2024 | 03:35 PM
Harvlr's Avatar
I see. So you’re not getting enough power to engage the starter solenoid then? Then it could be the switch, or a poor connection somewhere else in that circuit.
Old Mar 15, 2024 | 01:56 PM
whowa004's Avatar
will it start if you jump it? could be the battery is essentially dead or almost.
Old Mar 15, 2024 | 05:04 PM
Default Battery is fine
Fully charged. Starter works- just not engaging from ignition switch.
Old Jun 7, 2024 | 01:41 PM
Default Bump
Just thought that I would bump this to see if any of the RRC gurus could be of any help. All of the details are in the opening post. Thank you in advance.
DiscoNewbe
Nov 13, 2021 05:56 PM
san988
Nov 18, 2020 06:26 PM
nrthmbrlnd
May 8, 2019 01:05 PM
NZDiscoowner
Jul 17, 2017 05:28 PM
vette427sbc
Sep 18, 2014 03:55 PM
